1st oil change and...
Old Jan 31, 2002 | 06:57 AM
machokow's Avatar
Default 1st oil change and...
I took my car in for service the other day for my first oil change with 5,000 miles showing on the ODO. When I drove it off their lot I noticed an immediate difference (night and day... OMG is this the same car difference) in the revs (when shifting gears) and engine idle. Did any of you guys notice a big difference from your first oil change? I checked and maintained my oil level on every fill up.
John
Old Jan 31, 2002 | 10:21 AM
cdelena's Avatar
There can be notable viscosity differences at room temperature from one oil to another that may make a difference in feel when the car is first started. Once up to full operating temp most of that difference disappears and with it any power difference. There is measurable pumping loss difference between viscosities, but power differences between oils of the same viscosity at full operating temperature is very close to nil.
Old Jan 31, 2002 | 10:34 AM
mav's Avatar
mav
I noticed a slight difference when I went from standard oil to synthetic oil at 8800 miles. The power seemed smoother and mileage definitely improved.
Old Jan 31, 2002 | 02:03 PM
machokow's Avatar
cdelena- the noticeble difference is felt when the car has reached full operating temps. Before the oil change no matter how smoothly I tried to shift each gear the car would jerk a little (to a lot) due to the revs, this was the case for both up and downshifts. Now after the oil change I can almost pop the clutch with no noticeble jerkiness. Quite odd. I'm not complaining or anything the car drives much smoother now then bofore.
Old Jan 31, 2002 | 02:15 PM
cdelena's Avatar
I won't argue what you feel but IMO the oil has nothing to do with it.
Old Feb 5, 2002 | 06:13 PM
Nobody's Avatar
Same thing happened on my FZR - but then again the FZR's transmission and engine oil were one and the same. Not so w/the S2000.
SebRedAP1
Sep 28, 2009 02:35 PM
GranPrix
Oct 1, 2008 11:24 PM
mjirvine
Apr 30, 2004 11:51 PM
Archon
May 3, 2002 10:35 AM
