2001 Honda S2000 - Driveshaft Leak Help!
Hello,
My 01 Honda S2000's drive shaft is leaking the grease out. Is it safe to drive around still?? I got quoted $1900 for part & labor!
The mechanic said there's no aftermarket for my car's driveshaft or 'propeller shaft' they said I would have to go OEM which the part itself is list $1456
I found online a used 94K miles driveshaft for $325. Not sure if it's a good idea though or just save up and go new.
My main questions;
Safe to drive meanwhile?
New or used?
Here's a pic, thank you!
My main questions;
New or used?
You can find them used on this forum all the time, just go used, the new price is outrageous. Try to find one with less miles than the one that you noted, the lower the better.
00-03 Honda S2000 OEM axle driveshaft drive shaft AP1 | eBay
2000 00 HONDA S2000 AP1 OEM FACTORY DRIVE SHAFT ASSEMBLY AP1 F20C S2K #3133 | eBay
2000 00 HONDA S2000 AP1 OEM DRIVE SHAFT | eBay
2003 03 HONDA S2000 AP1 OEM 6 SPEED DRIVE SHAFT ASSEMBLY AP1 F20C S2K #3172 | eBay
2000 00 HONDA S2000 AP1 OEM FACTORY DRIVE SHAFT ASSEMBLY AP1 F20C S2K 3150 | eBay
Big hint vice grip + allen socket make short work of the bolts. The washers are as important as the bolts and should be replaced as worn ones can let the bolts back out. Get two bolts of each flange just in case, but if you do the socket and vice grip combo should be easy enough. It's a big help to have a helper put the car in and out of gear so you can rotate the shaft and get at each bolt. Other than that, piece of cake. Oh and there's a little hanger you have to remove, but that's pretty duh.
Its very easy, with the right tools. The allen heads can be easy to strip the heads. The shaft slides front to rear, so you slide it back to make room in front, slide fwd to get at rear bolts.
The right tool is allen head sockets. Once you have these, this job is cake.
If you strip the heads of any Allen bolts you will have to grind the head off to remove. Vice grips might help prevent stripping the Allen head but don't be surprised if you strip it. It's difficult to get a good grip on the bolt heads with vice grips.
