2002 S200 Maintenance Question
I recently bought a 2002 S2000 with 35,000 miles that was 1 owner car. I might have to end up selling it because of an addition to the family
but that is a different story..... I have noticed that after a detail and this last rain my car would get a check engine light. Both times it was a misfire code but I did not get which code it was. I am going to take my car to the dealer to see what they think, I heard it might be the spark plugs? Can anyone here shed some light on this for me? Below is my cars service history which has been done a Honda Dealer(s). My current miles are 35,400 or so....
1-29-2015 w/33,597 Miles: Oil and Filter Change and Transmission Service
2-11-2014 w/32,290 Miles: Replaced Serpentine Belt, New Transmission Service, RearDifferential Service, Brake Fluid Service
2-06-2014 w/32,234 Miles: Perform Minor Service, Oil and Filter Change
4-16-2013 w/30,521 Miles: New Rear Tires
2-15-2013 w/29,832 Miles: Oil and Filter Change, New Air Filter and New Differential Fluid
5-29-2012 w/27,547 Miles: Oil and Filter Change
12-19-2011w/ 25,092 Miles: Replaced Both Rear Differential Mounts
12-10-2011w/ 24,928 Miles: Perform Minor Service, Oil and Filter Change
5-13-2010 w/19,356 Miles: Oil and Filter Change
1-12-2010 w/17,713 Miles: Oil and Filter Change
1-06-2010 w/17,013 Miles: New Front Tires
5-18-2009 w/15,800 Miles: New Rear Tires
4-23-2009 w/15,536 Miles: Oil and Filter Change and Cabin Filter
1-16-2009 w/13,818 Miles: Oil and Filter Change
7-15-2008 w/9,876 Miles: Oil and Filter Change
5-03-2007 w/7,596 Miles: Oil and Filter Change
6-27-2006 w/6,350 Miles: Oil and Filter Change
4-18-2005 w/4,217 Miles: Oil and Filter Change and Replaced Battery
11-17-2003w/ 2,708 Miles: Oil and Filter Change
but that is a different story..... I have noticed that after a detail and this last rain my car would get a check engine light. Both times it was a misfire code but I did not get which code it was. I am going to take my car to the dealer to see what they think, I heard it might be the spark plugs? Can anyone here shed some light on this for me? Below is my cars service history which has been done a Honda Dealer(s). My current miles are 35,400 or so....1-29-2015 w/33,597 Miles: Oil and Filter Change and Transmission Service
33,600 miles and 14 oil and filter changes? Break-in engine oil was removed maybe 3000 miles too early but I've no clue what that might have done.. Spark plugs are good for 100,000 miles too. They may need to be torqued. Are they OEM?
-- Chuck
-- Chuck
They are OEM but according to the S2000 factory maintance schedule they recomend being replaced at 105,000 Miles/7 Years I am assuming that means 105,000 miles or 7 years. The car is 14 years old so I am sure it can be due because of time?
The 7 years to change spark plugs was dropped from later owners manuals but it won't hurt to change the plugs, they're inexpensive. New OEM plugs will come gapped and have anti-seize on the threads, don't add more. Torque spec was increased to 24 lb-ft a few years ago. Probably due to leaking plug holes.
-- Chuck
-- Chuck
It only happens when it rains?
Maybe the rubber sealing strip on the cowl is torn or leaking. Water could be getting onto the valve cover and seeping into the spark plug tubes.
Or...do you have a cold air intake?
I don't think it is that because I am usually pretty conscious about that….
I am going to have the guys at Rockstar Garage look at the car. They did a great job when I took them my car to look it over after I bought it. I had them do new oem battery and stainless steel brake lines..
I am going to have them look into this. I have been gone for a few days so hopefully I can have them look at it tomorrow…
This is what I think it is too so we will see. I have the full service history and do not remember seeing them being changed, so I am thinking mine are original as well….
My oil light is not on?
Ill double check that. My car is stock with no mods….
-- Chuck
-- Chuck
