2007 S2k Steering Angle Sensor
Old Feb 26, 2009 | 08:13 AM
crits2k's Avatar
Default 2007 S2k Steering Angle Sensor
Where is the steering angle sensor on an 06-09? Anyone happen to have a pic? Thanks!!
Old Feb 26, 2009 | 12:00 PM
Mrfixit687's Avatar
VSA SYSTEM DTC 27: STEERING ANGLE SENSOR.
SRS SYSTEM, 8-1: INTERNAL FAILURE OF THE SRS UNIT.
Old Feb 26, 2009 | 12:04 PM
crits2k's Avatar
Where is the steering angle sensor, maybe it just needs to be re-learned. Thanks
Old Feb 26, 2009 | 01:33 PM
crits2k's Avatar
Old Feb 26, 2009 | 04:31 PM
bgoetz's Avatar
steering angle sensor is in the steering column
Old Feb 26, 2009 | 05:46 PM
Mrfixit687's Avatar
What mods did you do to your car to cause the problems?
Old Feb 26, 2009 | 07:51 PM
crits2k's Avatar
Car was in an accident and I replaced the airbag and clockspring.
Old Feb 27, 2009 | 06:05 AM
soozookabluS2k's Avatar
^is ur vsa light on now? i think i have the same problem, removed my steering wheel and now its not str8 and the vsa light stays on
Old Feb 27, 2009 | 07:06 AM
crits2k's Avatar
Yup, my VSA light and Triangle are on. Sounds like we have the same problem, The dealership wanted over $300 to reset it and it takes under 5 min. I found out where it is, it is behind the clock spring integrated into the turn signal canceling body. I don't think that it can be reset without their nifty honda analyzer PGM tool.
Old Feb 27, 2009 | 08:07 AM
^damnnn yup i have the vsa and triangle on. 300 dollars to reset it is rediculous.. r u gonna have it reset?
