200psi compression?
You always hone the cylinders when you change the rings. If not they won't seat properly, but if you have to ask you should probably take it to someone experienced with s2ks. Check ebay for a blue point leak down tester.
See now the good part is that all your numbers are still within limits but here you go
note, you shoudl use about 1 tablesppon max oil per cylinder, no more
shoud dhave said that first time for best results.
If the compression reading goes up with oil in the cylinder, the piston rings and cylinders may be worn and leaking pressure. The oil will temporarily coat and seal bad compression rings to increase pressure; however, if the compression reading stays about the same, then engine valves or head gaskets may be leaking. The engine oil seals the rings, but does not seal a burned valve or a blown head gasket. In this way, a wet compression test helps diagnose low-compression problems.
shoud dhave said that first time for best results.If the compression reading goes up with oil in the cylinder, the piston rings and cylinders may be worn and leaking pressure. The oil will temporarily coat and seal bad compression rings to increase pressure; however, if the compression reading stays about the same, then engine valves or head gaskets may be leaking. The engine oil seals the rings, but does not seal a burned valve or a blown head gasket. In this way, a wet compression test helps diagnose low-compression problems.
