AT-205 safe for F20C?
Old Nov 3, 2020 | 05:01 AM
juno1996's Avatar
Default AT-205 safe for F20C?
Hey all, I listen to a particular YouTube mechanic who consistently touts a resealer product called AT-205. Well, I have what may be a very small leak at my rear main seal. Has anyone tried the AT-205 in their engines? (Did it work?) Think it's safe enough for my pampered S2000?
Thanks!
Old Nov 3, 2020 | 05:50 AM
windhund116's Avatar
Those "quick-fix" sealant solutions for the oil and coolant makes me real nervous. I've fixed a few bikes, where folks had put that kinda stuff into the oil or coolant. Ended up blocking small passages and ruining the motors.
Maybe best to replace the rear seal when doing a clutch job.
Old Nov 3, 2020 | 08:44 AM
Car Analogy's Avatar
I spray that stuff on EXTERNAL rubber parts, like cv boots and steering rack boots. Suspension bushings. Hoses.
Its a great rubber preserver. But its made for automatic transmissions. That's why its called AT-...
I wouldn't put it inside an engine. Ever. I wouldn't even put it inside an automatic trans unless the only other alternative was to rebuild it anyway.
Old Nov 3, 2020 | 08:53 AM
Kyle's Avatar
There's only one solution to a leaking rear main seal....bite the bullet and do it right.
Old Nov 3, 2020 | 01:19 PM
zeroptzero's Avatar
liqui moly oil saver is a pretty good product, riselone has a ring seal product too, using esters to improve seals safely.
K_iju
Nov 12, 2018 10:36 AM
ceophlo
Oct 22, 2016 03:29 AM
huck994
Socal Swap Meet
Dec 10, 2015 09:18 PM
Calzonii
Dec 6, 2015 11:21 AM
