2nd gear issue
shifting from first to second makes me wince every time from the clunkiness. from what i've read, it seems like its a common problem. is that the case?
also, i have grinded 2nd gear twice now... how much damage does that do to my s??
I still get some clunkiness (especially in 3rd) but it is a lot smoother after a tranny fluid change and diff. fluid change. Try them out if you haven't yet. I don't think you can eliminate the clunkiness, just make it better by warming up the tranny before punching it and keeping those fluids new.
This should help you after changing the fluid in the transmission and the clutch.
https://www.s2ki.com/s2000/index.php...&f=16&t=192881
My second gear is only slightly clunky on a cold start when it's cooler outside. After I shift into 2nd a couple of times it's cleared up. I just make a conscious effort to shift very slowly those first couple of times especially in the winter.
Changed the trans fluid with OEM honda @ 30k (currently at 39k). No difference from old fluid to new that I can tell.
It used to bother me, but I'm used to it now. I expect it for the first few shifts to 2nd gear, and then it's gone. I don't know where you rev to in 1st when cold, but like I said before...revving to ~3500-3800 in 1st and then shifting to 2nd nearly eliminates the cold clunk.
