3500rpms and cel
Old Nov 4, 2006 | 02:18 PM
AROD's Avatar
Default 3500rpms and cel
I have no way of hooking my car up to an obd2 scanner so i dn't know what code my car is throwing exactly. It will drive fine for like 10 minutes then the car wants to shut off and the cel comes on. I give the car alil gas to keep it running but it won't rev pas 3500rpms. If i let go of the gas it turns off. Any ideas??
ok i used modifrys idea of blinking cel, i recieved 5 short blinks. But i can't find a code for 5 short blinks anywhere, any ideas???
Old Nov 4, 2006 | 02:30 PM
gotswap's Avatar
map whack???
Old Nov 4, 2006 | 02:55 PM
AROD's Avatar
Originally Posted by gotswap,Nov 4 2006, 06:30 PM
map whack???
ive wacked the map, it clears up for another 5mins then does it again. I changed the map and it was good for another 20mins then it happened again
Old Nov 4, 2006 | 03:34 PM
djpeak10's Avatar
well if it won't excel past 3000 rpm than it is in limp mode which is not good. but honestly with out a code its all a guessing game.
Old Nov 4, 2006 | 03:40 PM
Slows2k's Avatar
Any # of DTC's can cause this. TDC, and CKP codes, and VTEC codes can all give you a low RPM rev limit. You still need the DTC before troubleshooting.
Being that your car is turbocharged what type of piggyback are you using?
Old Nov 4, 2006 | 04:21 PM
AROD's Avatar
using a greddy emanage. I recently unplugged the battery to reset the ecu, does the emanage get effected by this??
Old Nov 4, 2006 | 04:53 PM
Slows2k's Avatar
The emanage programming is stable after battery power is removed. The e-manage being wired in effects the troubleshooting as it's intercepting the some of same sensor inputs that can cause your problem.
Old Nov 4, 2006 | 04:57 PM
AROD's Avatar
i was thinking maybe that the map clamp wasn't set, but i know it was. I'm going to have to get the code to find out exactly whats wrong.
Old Nov 5, 2006 | 07:59 AM
AROD's Avatar
ok used the blinking idea, i see 5 short blinks, any idea of what that is??
Old Nov 5, 2006 | 08:37 AM
AROD's Avatar
anyone???
