4.44 FINAL DRIVE Error
Old Jan 17, 2007 | 08:17 PM
FMINUS's Avatar
Default 4.44 FINAL DRIVE Error
I got the 4.44 final drive and I just installed the yellow box
How many percentage is the error off by? 9%?
Old Jan 17, 2007 | 08:28 PM
Ustemuf's Avatar
0.076576576576576576576576576575994% assuming you are on the stock tire diameter.
Old Jan 17, 2007 | 10:02 PM
FMINUS's Avatar
hm... so setting it at 9% would help me on mileage on the odometer!
Old Jan 17, 2007 | 11:17 PM
OCMusicJunkie's Avatar
Yes, or you could set it to 50% and just do the math in your head
Old Jan 18, 2007 | 02:34 AM
brimstone's Avatar
(4.44 - 4.1) / (4.1) = 0.082926829268292682926829268292683
Thus, 08.29%
Hate to be the party pooper.
Old Jan 18, 2007 | 04:17 AM
SpitfireS's Avatar
IF the Yellow Box works the same as the Yellow Jacket then 7.66% is the correct answer.
With OEM 4.10 gears at a certain speed the gear box sensor will generate 1000 pulses.
With 4.44 gears, at the same ROAD speed, that sensor will generate 8.29% more pulses, being 1083.
To get back to the proper speedo reading (the original 1000 pulses at that speed) you'll have to "lose" 83 pulses.
So you start with 1083.
(1083-1000)/10.83=7.66
IMO 7.66% is the correct correction IF the Yellow Box works the same as the Yellow Jacket.
I'm sure the Yellow Box comes with a manual and setting examples
Old Jan 18, 2007 | 05:05 AM
brimstone's Avatar
My mind is blown
Awesome info as always
Old Jan 18, 2007 | 05:55 AM
jakub2000's Avatar
Thus, 08.29%
I have no idea why would you calculate it that way. (and get the wrong result)
Try 1-(4.1/4.44)=7.6576e
Old Jan 18, 2007 | 05:57 AM
SpitfireS's Avatar
brimstone Posted on Jan 18 2007, 03:05 PM
[QUOTE]Awesome info as always
Old Jan 18, 2007 | 06:56 AM
xXx butane xXx's Avatar
another idea: instead of making the adjustment of +.0765765 (or 7.657%), set the yellow box to -.6689 (or -66.89%) and switch the display to Kilometers. This will give you the correct speed and keep miles off your car. Other than being illegal I think it's a great idea.
math: (km to mi conversion 0.62137119) x (4.4 gear conversion 1.0765765) = .6689536 or -66.89%
