6 - 7 ---- Catalyst System Efficiency B
Old Jun 30, 2009 | 05:31 PM
mtls2k's Avatar
Default 6 - 7 ---- Catalyst System Efficiency B
Ok guys I got a CEL, so I checked the blink codes and got a 6-7, 6 - 7 -- Catalyst System Efficiency Below Threshold.
So that does this mean? Please help
Old Jun 30, 2009 | 08:16 PM
mtls2k's Avatar
Anyone??
Old Jul 1, 2009 | 03:05 AM
Slows2k's Avatar
It means you need a new catalytic convertor if you want to remain emissions legal.
Or you installed a test pipe.
Old Jul 1, 2009 | 05:50 AM
mtls2k's Avatar
Nope, to my knowledge there is no test pipe, its all stock
If I dont care about being emmisions legal can I just remove the cat, and replace it by regular tubing? Then bypass the sensor"?
Old Jul 1, 2009 | 07:43 AM
Stratocaster's Avatar
regular tubing? = Test Pipe
Then bypass the sensor"? You will need to "Fool" the sensor. Some Test pipe has an mount for the O2 Sensor that pull is back out of the stream. For others, the anti fouler trick seams to work.
Do a search for Test Pipe.
Old Jul 1, 2009 | 06:13 PM
mtls2k's Avatar
Ok, I'll do a search for a test pipe, but in the mean time, how do I know that the problem is the Catalytic convertoer, and not the sensor?
does the CEL throw a different code if the sensor has gone bad? or is it the same code for a bad sensor as it is for a bad catalytic converter?
I just dont want to go through the headache of trying to find a catalytic converter, or a test pipe, spend the money only to find out that it was just the sensor.
Old Jul 1, 2009 | 06:14 PM
Slows2k's Avatar
P0420 is always a converter, not a sensor issue.
Old Jul 1, 2009 | 06:24 PM
mtls2k's Avatar
Ok, thanks!!
Where do you suggest I shop for a test pipe? Any on-line stores with good prices??
THanks again!!
Old Jul 1, 2009 | 06:39 PM
S2Kage's Avatar
Ebizzle homie!
Old Jul 1, 2009 | 07:08 PM
mtls2k's Avatar
Originally Posted by S2Kage,Jul 1 2009, 10:39 PM
Ebizzle homie!
You mean Ebay, right?lol!
