On 6Psi / Rear End
Old Oct 14, 2007 | 08:02 PM
Scott Howard's Avatar
Angry On 6Psi / Rear End
On 6 psi how long will the rear end last if I dont floor it everywhere I go? Just an estimate.
2001 S2k
I have a big pile of money I wanted to dump into my car like and idiot but Im not sure whether to go N/A or Turbo. ( worried about the rear end ). With an N/A setup I have no idea what else to use or do other than using supertech valvetrain for the head.
Old Oct 15, 2007 | 06:36 AM
negcamber's Avatar
It seems that the big killer for our diff is launching. You should be fine so long as you don't launch...but that might be hard to resist for long.
For a long term solution, send a PM to S2KPUDDYDAD...he's done some impressive stuff to make the diffs stronger.
Old Oct 15, 2007 | 11:54 AM
So basically if your going over the stock HP rating whether it be Turbo or N/A its gonna screw up later on. ( Ive launched my car like 3 times the whole time ive had it )
Old Oct 15, 2007 | 12:05 PM
negcamber's Avatar
Depends on the NA hp...unless you are going stroker you should be ok to launch occasionally. My diff lasted 60k miles with maybe a total of 2 dozen launches in 6 years ownership with only bolt-on NA mods.
Personally, if I ever went FI or big stroker, I would be getting a reinforced diff to go along with it.
Old Oct 15, 2007 | 01:16 PM
Well if I went N/A it would be supertech valvetrain, cams, port and polish, new ECU. I have Comptech Intake, HKS exhaust, stage 3 clutch, and flywheel already.
F/I setup would be a RevHard Turbo kit set at 6psi / with all new springs retainers and honda valves. and a Tune....
I dont launch my car ever after my friends diff. broke.
Im at work so I cant type a giant story about it, haha.
Old Oct 15, 2007 | 01:48 PM
ChefJ's Avatar
my diff is fine on more then twice that pressure.
Old Oct 15, 2007 | 05:59 PM
I just got a compression test done an hour ago and it was 197psi, 200psi, 185psi, 190psi. (124,000 miles). Im really leaning towards turbo but im unsure about turbo on stock internals. On youtube it looks as if its common to run turbo on stock internals. Thoughts???
Old Oct 15, 2007 | 10:03 PM
s2kbtos's Avatar
ya, well i did my compression today and i got 175,175,175,179....
66800 miles
Old Oct 15, 2007 | 11:23 PM
S2oooNvegas's Avatar
add the ap2 delay valve, wallah! no more snapped diff. and 6 psi couldnt squash a fly, so no worries.
Old Oct 16, 2007 | 11:26 AM
Well if 6PSI is more than safe, whats a safe boost? 10psi?
