about mugen intake
Old Apr 13, 2004 | 07:50 PM
shaolin's Avatar
Default about mugen intake
hey guys,
i got few question about the mugen intake.
1. if i do get it, besides taking off the stock intake, do i have to take anything else apart?
2. will it rub the hood?
thanks for any comment.
Old Apr 13, 2004 | 07:57 PM
CyrusA's Avatar
you have to cut a portion of the hood
Old Apr 13, 2004 | 08:03 PM
shaolin's Avatar
the hood or the heat shield or what ever you called that?
Old Apr 13, 2004 | 08:06 PM
ninegrand's Avatar
The hood. Use search to find a few "how-to" threads and you will get an idea what is all involved. The hood cutting part sounds worse than it is.
Old Apr 13, 2004 | 09:47 PM
JL9000's Avatar
You will have to cut part of the underside of the hood, but it doesn't have to be as big as the instruction suggests. You will also have to cut part of the air guide between the bumper and radiator. Then you'll need to drill a few holes on the cross beam that sits below the intake.
Good luck.
Old Apr 13, 2004 | 10:53 PM
shaolin's Avatar
damn, that's a lot of work. if i get cf hood do i still have to cut them?
thanks for all the info
Old Apr 14, 2004 | 09:10 AM
JL9000's Avatar
[QUOTE]Originally posted by shaolin
Old Apr 14, 2004 | 03:55 PM
BlueS2000Boy's Avatar
i didn't knwo you have to drill holes in the cross bar.... that seems weird. i would assume mugen would make some sort of braket to make it fit. i need to find a goto garage bend pipe.
Old Apr 14, 2004 | 06:38 PM
CynCrvrAP1's Avatar
is there cutting for the j's intake? besides the air guides, what else has to be cut?
Old Apr 14, 2004 | 06:48 PM
JL9000's Avatar
Mugen does supply brackets, but you have to drill holes on the cross beam to attach them.
