ABS light on, but EPS light blinks when jumping OBD2 pins
My ABS light is on, and ABS does not work. EPS light is not on. Jumping pins 4 and 9 on the OBD2 connector results in the EPS light flashing and the ABS light staying solid. What codes am I getting - ABS or EPS? The codes are 22 and 34 if it makes a difference. If these are actually EPS codes, why is my ABS light not blinking any codes?
Small update: went to a small indy shop to see if they could scan it and the result was "no communication". I don't know if it was his scanner or if the module is dead or what. Fuses are good. I guess I'll have to make the trek to the Honda dealer and see if they turn anything up.
Yep, I figured it out but forgot to update the thread. It was a blown fuse, but it was NOT the fuse that's labeled ABS. That's what screwed me up. I believe the fuse that popped was labeled for power mirrors or something like that, but it also serves the ABS system. Hope your fix is that easy. I went through the hassle of changing the ABS pump and module like an idiot before I found out about that other fuse.
I can't remember where it was located but I do remember that it was definitely for the power mirrors. I remember they stopped working but my windows and locks were fine. I think it was in the cabin, but can't say for sure. Just check the labels for the power mirror fuse.
if lookz kill
Nov 29, 2006 04:06 PM
