ABS Sensor?
Old May 11, 2009 | 11:09 AM
okcbrad's Avatar
Default ABS Sensor?
Hey everyone.
I have a 02 S2K and have had a weird problem since new. When I slowly drive into a parking spot, a lot of times my ABS will activate. I am not going even remotely quick enough to get them to engage.
Is it a sensor problem? Can you adjust them?
I know I am not sliding and my tires are not worn and it happens in the dry and wet.
Any help would be appreciated
Old May 11, 2009 | 03:53 PM
okcbrad's Avatar
Anyone?
Old May 11, 2009 | 05:48 PM
negcamber's Avatar
What wheels and tire size do you have?
Old May 12, 2009 | 06:38 AM
okcbrad's Avatar
I have the stock rims and stock size tires mounted on them.
Old May 13, 2009 | 04:08 PM
okcbrad's Avatar
Old May 13, 2009 | 05:45 PM
Slows2k's Avatar
Any suspension work or axles replaced?
Old May 14, 2009 | 07:02 AM
okcbrad's Avatar
Not that I know of.
Old May 14, 2009 | 07:23 AM
Wildncrazy's Avatar
Clean the wheel sensors. It's rare, but sometimes dirt, grit, whatever can get up there. Yes, I know they are magnetic and dirt's not, but it happened to me on a truck after a little off roading excursion.
Old May 17, 2009 | 04:44 PM
s2000guy's Avatar
Check for damage on the trigger wheel/pulser which is located on the outer cv joint just under the speed sensor.
Old May 18, 2009 | 07:55 AM
s2steve's Avatar
I have seen this a few times on non-s2ks. The ring that the wheels speed sensor reads ends up getting a knick or crack in part of it, which causes the ABS to engage. It seems to only happen at low speeds, though.
