AC Delco same as GMSFM trans. fluid?
I'm ordering it off Hardtopguy for the first time, and it doesn't look the same, so I'm asking - is it the same stuff?
http://www.hardtopguy.com/store/prod...?productid=254
Google the part# 10-4014 and ACDELCO.
You'll find enough info that it is "the same" as the #12377916 GMSFM.
"The same" as in: a substitute/replacement/if-your-trans-spec-is-to-use-the-one-you-can-use-the-other-too
Also, GM owns ACDelco.
