AC Delete Question
Old Jan 13, 2013 | 03:12 PM
Smurf_9K's Avatar
Default AC Delete Question
Hey guys, I'm new to the S2000, and I'm pretty sure I know the right course of action from searching but wanted to be sure.
I have an '02 AP1 and want to delete the entire AC system. I've done this before on all my other "fun" cars, and with the S being a convertible it's a no-brainer for me. I would like to take it to a shop to purge the system. However, the serpentine belt I have is shot and has cracks showing, so I want to replace it immediately, and I don't want to replace it twice.
Would it be ok to order a shorter AC delete serpentine belt and just bypass the AC compressor until I can have it purged and removed?
Would an OEM CR AC delete serpentine belt work on an AP1?
I'm pretty sure I can, but like I said I just want to be sure for peace of mind. Thank you in advance.
Old Jan 14, 2013 | 01:14 PM
Smurf_9K's Avatar
I went ahead and ordered a CR delete belt
Old Jan 14, 2013 | 02:03 PM
_brandon's Avatar
Unless you absolutely never use it or its a track car id leave it in. The ac when its off doesnt really draw any power from the engine because of the clutch. Only real benefit is weight reduction and I forget the amount of weight. You can leave it on with all the hoses off just undo the connector for it and plug the lines up.
Old Jan 31, 2013 | 03:02 PM
Smurf_9K's Avatar
Just to follow up, I installed the belt without issue and routed it around the compressor. Fit perfectly.
Man...that was the easiest belt change I've ever done...thank you Honda. Now I just have to evac the AC and remove it.
Old Feb 1, 2013 | 08:04 PM
preludepatrick's Avatar
It's R134A, just crack a line...it's really not too bad for the environment. A shop will charge you to recover your refrigerant and may very well end up re-using it and charge the next customer full price
Fran_s2k
Jun 4, 2016 07:16 AM
TG Racing Japan
Mar 8, 2012 02:13 PM
NickCastronova
Dec 18, 2011 07:00 PM
jimnasty23
Aug 6, 2011 01:38 PM
