Acceleration buzz?
Originally Posted by WindchaserS2K,Jul 17 2006, 02:35 PM
ok another question is I'm using an AEM EMS by changing the map sensor do I have to reset my EMS?
Originally Posted by WindchaserS2K,Jul 17 2006, 05:11 PM
Anyone
Again I apologize for not respoiding in a more timely manner.
Originally Posted by xviper,Jul 17 2006, 05:24 PM
This, I can't say, but if you know Shawn (UL), he's the master of MAP sensors on this car. It was he, who brought this whole thing to our attention years ago. Give him a call.
thanks guys for the input. Once again thanks a whole bunch xviper! I'll defintatly check this out. I also realize that this is only when i punch it into vtec. If i gradually go into vtec it's fine. Another point it that it only happens occasionally so i'm crossing my fingers to hope that this isn't my clutch.
Just an after thought. Is this motor supercharged like your last one? If so, what kind of plugs are you using? There have been some reports of experiences (myself included) of supercharged cars using Denso Iridium IK24 plugs. They have been known to give a high rpm miss at WOT, but then, the MAP sensor thing also gives a similar symptom.
the motor isn't supercharged =( i miss it at time but that's ok. I recently did a 30k maintenance and changed out the plugs to na spec plugs. I still have my 4.57 gears on. I also have a vafc tuned for my bolt ons (intake, header, exhaust, gears) would this affect it in any way. Any ways i'm taking my car out today and will be resetting the ecu and whacking the map a couple times. Hopefully this will fix it.
Certainly a VAFC "could" cause some engine running problems if something went wrong (degraded wire connections, ECU compensating for the settings, etc.)
When you deal with the MAP concentrate more on the wiring harness to ensure that it is wiggled around (to "freshen" up the connections) and to shove it on really securely. If this resolves anything, you should look into getting the new Honda zip tie mod to hold it down. It should only cost a few bucks or you can invent something on your own as I did.
yup i did the whole shabang minus the coolant flush. The diff fluid was changed, tranny, pollen filter, all the rubber seals under the gasket.
update* today i took my car out and after resetting the ecu and whacking the sensor a couple of times the hiccups comming from the engine is very minimal to the point were i'd say things are ok. xviper would you suggest that i pull the vafc off and test the car? It seems like its still there in the end of 2nd gear. 4th, and 5th seem good. At this point i'm hoping the noise is comming from my exhaust hangers? The car seems to run much better.
As for the noise, I'm afraid you're the best to locate that. Grab the exhaust tip and give it a good shake to see if you can duplicate the sound. Or you might have to jack it up and go under and give everything you see under there a good thump with your hand.
thanks. yeah i think i'm going to go with getting a new map sensor. Keep in mind this motor is off an MY00 that was stictly a show car. I will definately keep you posted.
