aem intake
Old Feb 18, 2007 | 10:01 PM
Qs2k's Avatar
Default aem intake
i got an aem intake on my s. i was just wondering when it rains will it suck up water? should i worry?
Old Feb 18, 2007 | 10:09 PM
AP2autox's Avatar
http://www.evasivemotorsports.com/merchant...Code=AEM-Bypass
Old Feb 18, 2007 | 10:47 PM
jdmgpw04's Avatar
i know in one case even with the bypass it suck so much water killed the engine...i guess as long you dont hit a puddle i guess your fine... but honestly take it off.. just get a comtech or any other than aem ...
Old Feb 18, 2007 | 10:50 PM
Qs2k's Avatar
soo take it off? h0w much d0es c0mtech go for?
Old Feb 18, 2007 | 10:55 PM
Qs2k's Avatar
its short ram right now would it still suck up water?
donger274's Avatar
forget comptech, g0 f0r 0em kn drop in and spoon snorkle or any snorkle
Old Feb 19, 2007 | 04:07 AM
umair_k's Avatar
Snorkle so far works the best, use stock air box and add a snorkle to it which can be easily removed when it rains, you can still use our car. a drop in filter can be an add on.
Old Feb 19, 2007 | 10:19 AM
rustywave's Avatar
in my experience, you're fine if you hit puddles. puddles aren't a problem...it's only when you try and cross a river (mid-wheel high water that submerges the filter) that you'll have a problem. which is what i went through.
luckily i got away with a spark plug and oil change, but it coulda been a lot worse. also, i am keeping the V2 on my car.
Old Feb 19, 2007 | 01:33 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
This is from an s2k with an AEM, the guy wasn't even driving. Melting snow filled the intake overnight. Blew the engine immediately on start-up.
Old Feb 19, 2007 | 01:41 PM
rustywave's Avatar
^^ would it have made a difference if they had a V2 rather than a V1? since i've had mine on (late summer), i've driven through downpours and through lots and lots of snow. the car's also sat in all-day rain outside while i was at work, and started up fine. chicago's had some crazy weather in the last few months. haven't had any problems except for when i stupidly tried to make it through a flooded area.
i have the drain hole from the engine bay taped up, but no umbrella. also, i have a garage.
