Air Fuel Ratio help
Old Jan 1, 2003 | 10:19 PM
TeamRedlineS2k's Avatar
Default Air Fuel Ratio help
what up, i had just installed an autometer Air/Fuel Ratio gauge, and its reading lean all the time, is this correct on a basically stock motor, all i have a in injen intake right now, i hooked it up the pin c16 (white wire) on the ecu, im pretty sure its installed correctly, please correct me if im wrong, i read most post and most people are saying that it should be runnig rich........ please help, thank you!
Old Jan 1, 2003 | 10:40 PM
jerrypeterson's Avatar
Running lean all the time? What RPM's? What about at WOT?
Is it bouncing between lean and rich at partial throttle and idle?
Old Jan 2, 2003 | 12:33 AM
Sunder's Avatar
Umm, don't AFR meters need to be calibrated? The one I built has a little trimpot resistor for calibration. You need to put it on a dyno first, to get a base reading, align it, and from then on, it's correct.
Old Jan 2, 2003 | 03:57 AM
BlackS2000Turbo's Avatar
TeamRed:
First I would double check the connection and verify that you do in fact have the correct wire. Those gauges by nature are very "jittery" for lack of a better term. All they do is read the output from the O2 sensor and basically give you a visual representation of the voltage that it reads. What I would do for a more accurate picture of what it's reading is take the car ouy and keep a steady 3000 rpm. At that point you should be able to see what youre narrow throttle ratio is. Then make a couple of WOT runs and watch it then. When you make a rapid change in throttlw position you're going to get bouncy readings and they are not indicators that you have a problem. Let us know how you make out.
Sunder:
The autometer digital AF gauge doesn't need to be calibrated because it simply reads the sensor output from the O2 sensor.
-BS2KT
Old Jan 2, 2003 | 07:04 AM
Yellow Streak's Avatar
Does your gauge look like this when driving?
It should look like that unless you are WOT, at which point it should be in the green.
-YS
Old Jan 2, 2003 | 07:11 AM
mine looks red all the time, no matter what im doing.......... hmmmmmmmmmmmmmmmmmmmm, does anyone know if c16 is the right pin to tap? thanx for all your help!
Old Jan 2, 2003 | 07:20 AM
I don't remember exactly which one I hooked it up to. I followed the Auto Meter directions and cross-referenced it with the Helm manual. If you are getting red all the time, you likely have the wrong wire. Check the Helm manual again and see which other wires there are for the primary O2 sensor.
-YS
Old Jan 2, 2003 | 07:28 AM
cjb80's Avatar
Try C-15. Here is the wiring diagram from AEM
http://www.aempower.com/bbs/download.php?id=13
From what I understand the secondary O2 sensor is the one before the catalitic converter. The readings after the cat will be more lean than what it actually is. This could be your problem...
Really you should just get an AEM EMS, wideband w/ display and get rid of that catalitic converter. Get a turbo too. Oops... j/k
Chris
Old Jan 2, 2003 | 07:33 AM
The primary is in the header (before the cat). The secondary is in the cat.
-YS
Old Jan 2, 2003 | 09:01 AM
Yep, primary is the one before the cat with the white heat guard on the wires, the secondary is the one in the cat with the blue heat guard on the wires. Trust me... it was an expensive lesson to learn!
