Airbag Install from AP1 to AP2 Wheel
Just put in an 07 wheel in my AP1, noticed that the plugs are different for the airbags, so i took the ap1 bag, and put it on the ap2 cover and installed it...now im wondering how to get rid of the srs light that i have??? thanks for the help!!
Either the airbag is faulty, or you turned the key on when it was unplugged. The plugs are different because the bags are different. Don't try cutting the plugs and swapping the 2 bags. It won't work.
Originally Posted by chViETnk,May 5 2009, 06:08 AM
try unplugging the battery? it should reset everything if im correct.
the same happen to me last week and i try disconnecting the battery even for a complete day and nothing, so i connect the scanner in the OBDII diagnostic port and select the SRS menu and the code appear as: high resistance or disconected air bag circuit. just reset that code and youre ready.
NikosX
Jul 9, 2009 05:28 AM
