Alignment
Old Feb 18, 2006 | 07:06 AM
s2000from canada's Avatar
Default Alignment
Hi Guys,
My car is a 2000 S2K with 50000 miles. It has been lowered 1 inch using Tein Springs.
My issue is that my car pulls left only under acceleration and at different speeds anywhere to 60mph. This ONLY HAPPENS UNDER ACCELERATION not when I am coasting. When I don't step on the gas (coast) it goes in a straight line...step on the gas and it verges extreme left.
Is this normal? This is my first s2K and I bought to used. I guess I can start with an alignment but I'm confused since the car only does this under acceleration...even mild acceleration.
Thanks
Old Feb 18, 2006 | 07:31 AM
Kobe's Avatar
did you check the tire pressures and adjust accordingly?
Old Feb 18, 2006 | 08:29 AM
cntcu's Avatar
i agree, i would definitaly check tire pressure..
Old Feb 18, 2006 | 10:02 AM
apex2k's Avatar
x 2
Old Feb 18, 2006 | 12:00 PM
WalkingDrunken's Avatar
x3 I had the same problem and it was just really low tire pressure.
Old Feb 18, 2006 | 12:21 PM
ayS's Avatar
ayS
x4
Old Feb 18, 2006 | 02:31 PM
Yflyer's Avatar
If it is not tire pressure, then perhaps the thrust line is not parallel to the axis of the car. Then you would get a pull only under torque. A good 4-wheel alignment shop can fix that.
Old Feb 18, 2006 | 10:50 PM
Eluded's Avatar
Originally Posted by ayS,Feb 18 2006, 01:21 PM
x4
x5
Old Feb 18, 2006 | 10:57 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
tire pressure
Please check it and let us know what you found.
Old Feb 19, 2006 | 01:37 AM
RACER's Avatar
Originally Posted by Eluded,Feb 18 2006, 11:50 PM
x5
x6
