alignment with coilovers
Old Mar 10, 2004 | 09:20 AM
payyourtoll's Avatar
Default alignment with coilovers
this may be a dumb Q but I've been wondering about it.
I know to get an alignment after the new suspension went in and it settled a bit. But what about when I lower the car an extra inch or so, then bring it back up to whatever height I think it was aligned at? Is an alignment needed after each and every height adjustment, or just after a noticeable change in height?
I read this over before posting and it kind of makes sense
Old Mar 10, 2004 | 10:04 AM
heffergm's Avatar
Your alignment is going to change when you raise/lower the car.
So I'd suggest at least marking the height you get the car aligned at, so when you put it back, you're in the ballpark.
Old Apr 20, 2004 | 09:21 AM
I am having trouble finding a shop that can correctly align the car after it has been lowered. They can align it to stock specs but that will not work. What have people done to get this right?
Old Apr 22, 2004 | 04:16 AM
bump for some help!
Old Apr 22, 2004 | 04:45 AM
jahwerx's Avatar
in NJ, I have a GREAT alignment shop that gets it to within 0.1 degree of what I specify.
Yes, I'm also lowered w/ CO's
Its a 4-wheel drive truck shop!
http://www.ok4wd.com/
Old Apr 22, 2004 | 05:33 AM
thanks - I am actually a customer of OK from my trucking days.
I guess what is a blank to me is when you say "what I specify" - how do I know what specs to tell them to align to?
Old Apr 22, 2004 | 06:18 AM
jahwerx's Avatar
This is what I'm running now
Left Front
Camber -1.8
Caster 6.9
Toe -0.01
Right Front
-1.8
6.9
-0.01
Left Rear
Actual
Camber -1.6
Toe 0.02
Right Rear
Actual
-1.7
0.07
next alignment, I'm going to pull 1/2 degree out of the front camber.
check this out: http://forums.s2ki.com/forums/showthread.p...=race+alignment
mosDEAF
May 5, 2012 08:28 AM
mrjoshuanyc
Mar 17, 2011 03:03 AM
jhp012
Dec 6, 2008 09:12 PM
mwy23
May 8, 2006 09:52 PM
ludeboye
May 1, 2006 06:05 AM
