alignment issues
Old Nov 6, 2014 | 01:06 PM
dru5o4's Avatar
Default alignment issues
i got my car back from an accident last year and finally noticed that the side that was hit made a strange tire sound. took off the tire and the inside was worned down to the metal, so after new tires and a trip to the alignment shop they said they couldnt get the toe because one of the tabs were bent. it is possible to fix this by buying a rear anti bump steer kit?
Old Nov 7, 2014 | 04:46 PM
blwn34's Avatar
Please take this car to someone that has a clue about alignments. I have been doing alignments for 26 years and the S2000 is one of the easiest cars to align if you actually now what you are doing. Where are you located? I can't stand to see posts like this. Just because a shop has an alignment machine does not mean they know what they are doing.
Old Nov 7, 2014 | 07:47 PM
dru5o4's Avatar
im located in new orleans LA, i brought it to multiple firestones and they said they wouldnt touch it because the alignment tabs are bent?
Old Nov 8, 2014 | 06:15 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If they are telling you they can't align it because of a bent tab (the little black subframe tabs that back the eccentric adjuster), they are incompetent and don't belong working on bicycles let alone cars.
But if they can't get you in range, you likely have a bent knuckle. It would explain your negative/low right rear toe.
Look at the part of the knuckle that holds the lower ball joint. If it is touching the backing plate, the knuckle is bent in. It's the first part of the knuckle that bends, during a light curb contact. Compare it with the left side.
That car must be all over the road.
Whatever happened to thinking/working outside the box? Are these Firestone places really that dumb?
BTW the alignment in the front is a train wreck as well.
Old Nov 8, 2014 | 06:21 AM
Billman250's Avatar
Top Answer: 1
Then again, they must be REALLY friggin dumb, being that your right rear toes was +0.51 when you started
Stay away from firestone at all costs, post in your local forum and find the right guy.
Old Nov 8, 2014 | 12:18 PM
blwn34's Avatar
Yup they obviously don't have a clue rear camber and toe will affect each other they have to be adjusted at the same time. Please find someone close to you that knows how to align a vehicle correctly.
Old Dec 15, 2014 | 10:25 PM
jack03ap1's Avatar
Looks to me like it drifts to the right according to the specs
Old Dec 23, 2014 | 07:11 PM
Nippon's Avatar
And what's up with the thrust angle? Was your car ever in a wreck? :-(
Old Jan 16, 2015 | 06:35 PM
Th@n@tos's Avatar
Did you ever get this resolved? I have somewhat of the same issue from Firestone as well.
Old Jan 16, 2015 | 07:41 PM
Slowcrash_101's Avatar
The solution is take it somewhere else.
dru5o4
Nov 6, 2014 01:35 PM
bbt4
Jul 24, 2006 10:11 AM
tabach0y273
Apr 8, 2005 05:55 PM
Legal Bill
Apr 22, 2003 04:42 AM
