alignment out of whack
Old Aug 11, 2010 | 04:15 AM
josserman's Avatar
Default alignment out of whack
I just went to get my alignment done after putting bigger wheels/tires on and they were not able to get my rear camber within spec. Any idea's on what would cause this?
rear left camber -2.6
rear right camber - 2.0
Old Aug 11, 2010 | 04:44 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Are you saying they could not get the numbers any more POSITIVE than what you posted? What is the goal?
Old Aug 11, 2010 | 11:34 AM
ddess's Avatar
I have the same issue with the front. Right side is only capable of -2.0 while the drivers side can get to -2.6. I thought that was a huge margin from side to side.
I pulled the wheels to check the A-arms just to see if they were bent and they looked fine.
Anyone else have an idea to why such a large difference between right to left?
Old Aug 11, 2010 | 11:37 AM
josserman's Avatar
that was the closest they could get the camber to stock. Going up to rodney (chris) to check it out today. I think it may be one of my bushings.
Old Aug 11, 2010 | 11:38 AM
josserman's Avatar
and billman, the good news is they got my camber in a much better position then it was when you saw the car at techday. that left wheel was around -4.0
Old Aug 11, 2010 | 01:08 PM
crank's Avatar
maybe the front subframe is to the left/right more on one side than the other?? i know its got 6bolts but im sure its possible
Old Aug 11, 2010 | 06:23 PM
ddess's Avatar
I didn't even think of that. Hopefully something like that happened at the factory. Ill have to look at it next time its on a hoist.
rpmgem
Feb 21, 2018 11:55 AM
Fat
Apr 21, 2017 04:25 AM
tekknikal
Oct 27, 2009 06:27 PM
teamking
Mar 25, 2006 01:34 PM
Zach H
Mar 10, 2004 02:38 PM
