alignment problem
I did an alignment tonight and it really went horrible.
The rear is my only issue. The car is dropped an inch.
RR is going between -0.08 and -0.01
LF is between -3.2 and -2.4
I have the LF at the lowest I could get -2.4 and right hand landed on -.06 when the toe was set. Rear subframe issue? Toe came into specs with ease if that matters.
Thanks guys
Thanks guys
Thanks guys
Thanks guys
When you give measurements you need to provide the units and what measurement you are referring to? Camber? Toe? You say the rear is your only problem, but you refer to LF and RR?
I hope that helps.
Guess I worded it funny and I did mess up. left rear not LF.
This is a camber issue, toe came into spec. It is only on the rear.
Rear left wheel camber is set to the lowest adjustment I could get -2.40
Toe -0.05
Right rear wheel would go between -0.08 and -0.01
I landed on -0.06 when the toe was set.
toe on that side is also -0.05
Only suspension mod is KG/mm springs.
I'm trying to get -1.00 out of the rear, or atleast a good common number.
Front specs are 0.00 toe and -0.08 camber on both sides and caster is set a little high at 6.4
Toe -0.05
You loose your camber adjust ability when you lower the car. I've done several other alignments on lowered cars where -2.0 to -2.5 is the lowest camber reading possible.
The fix is to raise the ride height.
