Alignment problems
Old Jun 8, 2014 | 04:51 PM
Nemui's Avatar
Default Alignment problems
Alright guys. I need your help. I went to get my car aligned and turns out my alignment is way off. Unfortunately the car I bought was in an accident on the left driver rear which is causing the alignment to be off.
If any of you could look at the alignment specs I have taken a picture of the actual alignment sheet given to me by the place that tried to align it and see what could be the cause of this problem. I have already replaced the driver's side front and rear upper control arms as well as the sway bar end link (broken) on the drivers side and tried to get it realigned but it still didn't help with the issue at all.
Any help is much appreciated.
Old Jun 10, 2014 | 01:29 AM
gptoyz's Avatar
Did you check the front and rear subframe alignment? The subframes could also be pinched, too.
Check the knuckle and upright too.
Ultimately, what you really should do is have the frame measured.
Sent from my iPhone using Tapatalk
CherryRed
Mar 24, 2015 11:24 AM
muha22752
Aug 24, 2012 02:10 PM
secretdonkey
Nov 5, 2005 11:39 AM
