Alignment problems...but alignment is identical?
Old May 17, 2013 | 07:29 PM
Mezza's Avatar
Default Alignment problems...but alignment is identical?
As you can see in the first photo the alignment looks fine, but in the second photo there is much more tyre and wheel visible on the left hand side than the right.
The first pic was -1 camber in the rear, and the second pic is - 2.5.
Both sides have identical camber, and I know this as I was given the sheet with the results after the alignment was done.
Offset and wheel widths are identical.
Is there a possibility they did not calculate the camber correctly?
I also thought that the car could be higher on on side possibly, or that maybe something else is the issue. The car drives perfectly, it's just bugging me...
Any suggestions would be most welcome.
Old May 17, 2013 | 08:45 PM
apme123's Avatar
are you sure the car wasn't spun and crashed before?
Old May 17, 2013 | 10:48 PM
Mezza's Avatar
Positive, there is no structural damage.
It seemed to happen after the second alignment was done. But with -2.5 negative camber the right wheel should look much more angled.
Old May 17, 2013 | 10:56 PM
SpitfireS's Avatar
And rear toe?
Besides... maybe the 2 subframes are not exactly in the middle of the chassis.
That way the alignment is perfect but the wheels are not "aligned" to the chassis.
Is it drives ok (left turn in is the same as right turn in, etc) and the tire wear stays equal its ok.
Old May 17, 2013 | 11:05 PM
Mezza's Avatar
Originally Posted by SpitfireS
And rear toe?
Rear toe stayed the same from the previous alignment, 1mm toe in on each side
Old May 18, 2013 | 08:09 AM
Mezza's Avatar
Could the bumper not be on properly?
Old May 18, 2013 | 08:50 AM
SpoiledAP1's Avatar
looking at the gaps between the body panels not enough to make it look that off. no wheel spacers or anything of that nature is there?
Old May 18, 2013 | 03:30 PM
BLAQ&GREYs2k's Avatar
No ideas or opinions matter in topics of alignments. Bottom line is whats the print out say? I do alignments daily and every client gets a print out. OR if your clueless, you dont ask for one and bro working on your car just sets "toe n go".
Id ask for a print out. They always show before and after.
Old May 18, 2013 | 06:30 PM
Mezza's Avatar
The print out has identical alignments for both sides. I asked for -2.5 camber and 2mm total toe in on the rear and that's what the print out says I have.
No wheel spacers are installed, although I do have driveshaft spacers.
Old May 18, 2013 | 07:43 PM
Ok well that is good. I dont feel proud admitting this but there are some techs out there that get lazy and move the sensors until they are within spec and hit print.. I'm not dissing wherever you take your S, just a thought.
IMO i think its just the way you are looking at it, or you are making yourself crazy lol. For reassurance, Id bring it to a different place or same place for alignment and ask to watch.
