Allignment issues
Old Mar 18, 2007 | 10:33 AM
starz's Avatar
Default Allignment issues
I have an 01 s2k and I installed ap2 rims which I understand are 17s instead of the 16s. The new rims have falcon 615's on them 255/40 in the rear and 215/45 in the front. Because of the new rim size and tires I did an allignment on it. It was nearly impossible to do it. Everytime I adjusted my rear the front would go out of allignment and visa versa. I would do my rear camber then the rear toe, and the rear camber would go back out. Then adjust my rear camber again and the rear toe would go out.
I was doing the allignment myself, but when i couldent do it, I had three techs try it and they couldent get it to allign eigther.
I bought my car as the second owner. It had a clean carfax and 7k miles on it. The undercarrage is in prestine condition. Not a single sign of an accident.
Is there somethign wrong with my car or is there a special way of allighning a s2k that im not aware of?
If it makes a difference my old front tires were bald on the outside and meaty on the inside and the rears had even wear. Also the new falcons I put on were second hand but look like their wear pattern is even.
Old Mar 18, 2007 | 05:52 PM
Utah S2K's Avatar
Find someone with a Hunter alignment machine that knows how to use it. Don't use the Honda factory settings but use the ones for the S in the Hunter.
Utah
Old Mar 19, 2007 | 02:13 PM
jyeung528's Avatar
so why is he unable to do the alignment with the ap2 wheels?
and does it have anything to do with the ap2 wheels???
Old Mar 19, 2007 | 02:47 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Switching to 17's is no reason to have an alignment. Nothing changes.
Billman250's Avatar
Top Answer: 1
First question is, what parameter can not be bought into spec?
Caster, camber, or toe.
Old Mar 19, 2007 | 05:54 PM
starz's Avatar
I started out adjusting the rear left camber. When I got my left camber within spec I began adjusting my right rear camber. I got the right rear camber in spec, so i began working on my rear toe. I adjusted my rear left toe and rear right toe. Then i looked at my measurements and the right rear camber went out of allignment. I did the process several times and I couldent get the rear camber and rear toe to all be within spec. I finally got them all nearly close so i began alligning the front. Started out with no problem. Everything went into allignment then i look back at my rear and both camber and toe went out in the rear.
AZS2KDancer
Jun 1, 2016 06:28 AM
AE_Racer
Jul 28, 2013 12:24 PM
JVS2
May 26, 2009 10:02 PM
s2kpearlwhite
Feb 26, 2009 12:21 PM
03_AP1
Jul 21, 2005 06:19 AM
