Another Cluth replacement
Old Nov 3, 2010 | 12:20 PM
kid active's Avatar
Default Another Cluth replacement
Hey s2ki fellow members, I've run into a clutch problem, and it seems like its just time to replace my clutch set up. Very hard to put into gears sometimes and slips once in awhile at high RPM. Anyways I have looked over the forums via search, and found out that the OEM clutch disk is actually very well built and stable for what I want to replace.
Set up that I am thinking about, that other s2ki members have done is ACT HD PP with a new OEM disc clutch for daily driven purposes. My question is, if anyone is running this set up, How is it? Any decel nose with the aftermarket PP? and What other parts should I replace since I'm already replacing my clutch setup?
Any help will be great! Thanks s2ki
Old Nov 3, 2010 | 09:44 PM
kid active's Avatar
any help?
Old Nov 4, 2010 | 03:24 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I've had my ACT PP, oem disc, oem throwout bearing, oem pilot bearing installed for 100k miles. It's great. You'll get no decel noise with an oem disc.
Old Nov 4, 2010 | 05:51 AM
deepbluejh's Avatar
Hard to put into gears? Sound like that might be a transmission (or fluid) problem, not a clutch problem. Slipping at high RPM is common for AP2 cars as well.
switchblaydes
Sep 19, 2018 05:33 PM
Jackzs11
Dec 12, 2015 03:51 PM
Captain_Liu
Feb 24, 2009 10:32 AM
chikai
Jun 1, 2005 02:23 PM
dhess
Apr 8, 2002 04:43 AM
