Another tranny issue
I have a 02 AP1 with 31k miles and the tranny is giving me two issues. 2nd is notchy when engaging and you can actually hear the "crunch", I also have a problem with 3rd and 4th but it's a little different. Going into 3rd and 4th half way into engaging either gear the shifter feels like I'm sliding something into a fan. This happens every single shift when the tranny is cold, once it warms up or after driving on the freeway for a while 2nd becomes smooth but 3rd and 4th still give me that problem but not as bad. I flushed the old trans fluid out and refilled it with Honda MTF and the problems still continue. Is this tranny toast? Lol
EDIT: Now that the car is parked for winter I've finally had a chance to work on it a little more. Popped off the clutch fluid cap and I noticed it was very low and extreamly black, topped it off a little and it was still really dark. I'm going to be flushing it tomorrow but I wanted to know if this could maybe be the cause of my notchy tranny? http://i98.photobucket.com/albums/l2...k/IMG_4793.jpg http://i98.photobucket.com/albums/l2...k/IMG_4795.jpg |
Originally Posted by fernando.
(Post 21095829)
I have a 02 AP1 with 31k miles and the tranny is giving me two issues. 2nd is notchy when engaging and you can actually hear the "crunch", I also have a problem with 3rd and 4th but it's a little different. Going into 3rd and 4th half way into engaging either gear the shifter kicks back so to say, I have to keep some force on the shifter or else it'll just kick back into neautral. This happens every single shift when the tranny is cold, once it warms up or after driving on the freeway for a while 2nd becomes smooth but 3rd and 4th still give me that problem but not as bad. I flushed the old trans fluid out and refilled it with Honda MTF and the problems still continue. Is this tranny toast? Lol
I doubt the clutch is worn out at 31k miles, it still feels great. You think the GM Synchromesh would help?
Tranny is junk, replace it with a ap2 if u are looking for one lemme know i think i know a guy selling one
-richie |
If you have to hold 3rd and 4th with your hand at low RPMs then your synchros on those gears are gone and your gears will be gone in about a year give or take depending on how often you drive and how often the gears pop out and grind.
(Post 21095860)
I do not have to hold the shifter when its IN gear, I can keep it in third or fourth, accelerate and it stays in gear. I'm saying it's difficult to engage 3rd and 4th because the shifter kicks back.
(Post 21096139)
Ahh, thanks. What I ment in the first post is as I'm sliding the shifter into said gear it wants to bounce back and not go in, once it's in it stays in gear perfectly fine! Will Amsoil MTF Synchromesh be better than GM Synchromesh? I've read that the Amsoil stuff is really notchy and hard to shift in colder weather.
lol I guess there are mixed reviews about it cuz I've heard the complete opposite. Amsoil is what I've used and it works like a charm! Just remember to go thru the gears everyday right before you start moving. Just the way you warm up to lube the engine and get the oil up to the right temperature, it's the same procedure with your transmission except that it's done manually of course. I usually start up the car, go clutch deep and I go thru all the gears including reverse about 3 to 4 times.
Every time I do it the 1st round 1st, 2nd and R won't go in gear. I dont force it into gear though cuz I would be defeating the purpose of lubing the gears for protection. The 2nd round 1st and 2nd are a little notchy but all of them go in gear, and after the 3rd round everything is nice and smooth. Just repeat as needed. I only drive my s2k twice a week so maybe that's why I made a ritual of it. |
