Any prob using 1 step colder plugs?
Old Jan 25, 2006 | 02:56 PM
MB's Avatar
MB
Member
Default Any prob using 1 step colder plugs?
I have some NGK BKR8EX plugs but the car is meant to run on PFR7B's.
Any issue using them? I cant see a problem - I bought them for my S/C install which is on hold but want to fit them, maybe long term N/A
Cheers!
MB
Old Jan 25, 2006 | 03:16 PM
Slows2k's Avatar
I ran a set of NGK 7173's for 10 months NA without a issue. No effect on engine performance for street use.
Old Jan 26, 2006 | 02:37 PM
MB's Avatar
MB
Member
Are they a step colder than stock?
The codes are different to UK ones!
MB
Old Jan 27, 2006 | 08:26 AM
RWD_RCKT's Avatar
I ran IK24 (Denso Iridium, 1 step colder than stock) on my AP1 for the street. But I fouled one of the plugs because I didn't drive the car hard enough. So I went back to the normal heat range (IK22) plugs.
For street use (or long term NA), I wouldn't recommend it unless you beat on the car. If you are only going to be NA for less than a couple thousand miles before you go SC... run them. You'll be fine. Just don't expect 10hp... or even 1.
Old Jan 27, 2006 | 05:19 PM
Slows2k's Avatar
7173's are 1 step colder, non-resistor copper core plugs.
Old Jan 27, 2006 | 05:44 PM
MB's Avatar
MB
Member
Thanks both, spot on!
MB
surfer_crx
Jun 15, 2015 05:04 AM
B0neSt0ck
13
Sep 1, 2014 07:24 AM
Owen_1987
Jul 18, 2011 09:34 AM
DJT
Jan 7, 2010 08:55 AM
s2konroids
Apr 21, 2009 03:27 AM
