Anyone have instructions for Mugen...
....intake install? If you do, can I ask you to a hard copy through snail mail or fax...or scan it in for a soft copy (email, pm, or posting will do).
Thank you!
....and yes, I did do a search.
PS. It's pretty self explanatory of how the install should go, however, I want to make sure that I have the mounting bracket to the horn correctly placed on the cross beam between the shock towers, and want to figure out how the bracket that holds the plumbing should be placed and mounted to the backside of the filter.
Any words of advice from others who have done this would be greatly appreciated.
Thank you!
Since I had to build my own brackets and went from a Comptech to the Mugen, I really didn't follow the instructions. Scott did fax them to me (has he stopped doing that?) and I will see if I can find them. A test fit of the bracket and intake will show it can only get screwed down in one spot. Since I had previously redone the vacuum lines, I did not even use the thing on the filter to mount lines. PM a fax number, and I will let you know tonight.
Chris,
I only have access to my work's fax machine, and unfortunately, I will not be in the office after today until January 4th.
If you or anyone else happens to have a scanner or a soft copy, to either post or pm, I'd greatly appreciate it.
