AP1 AC compressor
Old Mar 2, 2019 | 04:40 PM
Benji ap1's Avatar
Default AP1 AC compressor
My AP1 had low freon and with realizing I ran the AC until my compressor blew. Do I need a new AC condenser or AC evaporator? I already am replacing the compressor, high and low pressure line, and drier.
Old Mar 3, 2019 | 07:50 AM
Slowcrash_101's Avatar
No, not really, you can clean the condenser(with acetone and compressed air), and it's unlikely for debris to end up in the evaporator, because the drier and expansion valve will block any debris from entering. From the evaporator it's a one way ticket to the compressor via the suction line, so nothing is being forced into it.
The bolt going to the condenser can get soft because it comes in contact with a lot of moisture and oil and refrigerant, it can also seize inside the threads making it hard to remove. The worst case scenario is this happening and you shearing the bolt. If this happens you'll have to drill out the old bolt. But you can't drill straight through you have to leave a little bit of the old bolt.
Old Mar 3, 2019 | 08:11 AM
Benji ap1's Avatar
Thank you.
kundanp333
Feb 28, 2017 06:02 AM
redf20ae86
Jun 29, 2013 05:48 AM
Boss-S2K
Oct 9, 2012 07:06 PM
aristo 161
Mar 19, 2010 07:57 AM
black2000
Feb 28, 2010 02:25 PM
