AP1 Convertible Top Replacement
Old Aug 26, 2009 | 05:30 PM
sayaingokou311's Avatar
Default AP1 Convertible Top Replacement
Hey Im looking to get rid of my AP1 Convertible Top, due to the age of the top being almost 10 years old, and the holes starting and rips. Im getting a AP2 Top with Frame, can anyone give me some ideas about installation any pics DIY info would be greatly appreicated. THanks guys.
Old Aug 26, 2009 | 08:13 PM
s2k dre's Avatar
https://www.s2ki.com/forums/index.php?showt...0&#entry9360846
Old Aug 26, 2009 | 11:03 PM
iam7head's Avatar
search first
you don't need an ap2 top frame to run a glass top, search and read the faq
Old Aug 27, 2009 | 05:56 AM
heathas2k's Avatar
if you're getting an ap2 frame with the ap2 top already on it, it is much easier to install.
basically you're gutting your entire frame/top, and then placing the ap2 frame/top in it's place.
it's probably easier to do it if you take the seats out, but not neccesary. you have to start by taking off the panels behind the seats, the panels to the side, the center console, rollbars, and the panel behind the seats that the softtop sits on. It's ALOT of unbolting/unscrewing/taking out tabs.
to get to some of the rollbar bolts you need to go through the trunk. (take out the spare).
make sure you keep all your bolts and stuff in specific piles as you're taking them off, otherwise it will SUCK putting it back together.
you can start taking out the interior stuff with the top down, but will need to put the top back up to get to the back tray that the top sits on.
it's pretty simple, just very time consuming. a member on here in delval did mine with me, and it took us about 5-6 hours to do the complete swap. He had already gutted his ap2 top/frame, so that time just included taking mine out, and putting his on.
It's also easier taking the frame/top out and putting the new one in with 2 people. If you don't have two people holding the top you may have trouble making sure the top is aligned correctly when first bolting it in. I'm sure there's a DIY somewhere on here for the frame swap.
Good luck!
Old Aug 29, 2009 | 08:20 PM
Awesome guys thank you so much
Old Aug 29, 2009 | 09:33 PM
spectacle's Avatar
I hope you have a lot of patience. And beer.
NEVER again.
https://www.s2ki.com/forums/index.ph...pic=607764&hl=
Good luck!
Old Aug 30, 2009 | 03:59 AM
negcamber's Avatar
And DO NOT try to take the plastic off the roll hoops. Each roll hoop with plastic come out as one piece. If you separate that plastic it is hell to get back together (much super glue and cursing).
Old Aug 30, 2009 | 02:12 PM
hehe i just start taking off some of the plastic pieces today not bad so far........ im waiting for the hard stuff. The top will have the frame connected to it so should it be easier to get back in?
Old Sep 7, 2009 | 10:37 PM
do i really need to remove the 2 middle toneau male clips after the tops installed?? Please tell me i dont
Old Sep 8, 2009 | 02:48 AM
JasonSBAP1's Avatar
you should keep the top out and get a hardtop lol
