ap1 head w/ ap2 block
Old Mar 11, 2006 | 10:03 PM
clawhammer's Avatar
Would it be adviseable to bore out the holes for the rod bolts, and put slightly larger bolts in place, or would that actually be counter productive because it would weaken out the rest of the rod?
That would seem like something that could be done very cheap.
Old Mar 12, 2006 | 07:18 PM
Incubus's Avatar
Knock Knock
Who's there?
Trouble...
I was just looking for you!
Old Mar 12, 2006 | 08:00 PM
LUVNMBRS's Avatar
[QUOTE=Wisconsin S2k,Mar 11 2006, 10:20 AM] none of those cars has anything to do with the S2000.
Old Mar 12, 2006 | 09:46 PM
steven975's Avatar
Originally Posted by LUVNMBRS,Mar 12 2006, 09:00 PM
11,000 rpm...huh, how do you figure?
In terms of mean piston speeds, an AP2 at 9,000 rpm is equal to an AP1 at 9,718 rpm. Here is the undeniable proof:
AP2 at 9,000rpm= 90.7mm stroke x 2 x 9000rpm / 304.8mm per ft. = 5,356 ft. per min.
AP1 at 9,718rpm= 84mm stroke x 2 x 9718rpm / 304.8mm per ft. = 5,356 ft. per min.
if you are only comparing the piston speeds, your calculations have merit.
but we're not. You need to consider piston ACCELERATION. the acceleration is NOT a sine curve. Then there's the substantial increase in piston side loading, putting strain on the very thin walls of the cylinder and adding substantial SHEARING force to the bottom end, including the bolts.
putting those things in the picture, 11,000 sounds more accurate to me.
Old Mar 13, 2006 | 12:22 AM
AusS2000's Avatar
Guys, we go on and on about this all the time. Yet the results from people who actually do it seem to contradict the predictions.
My take on it is that Honda have a certain acceptable failure rate and that to maintain this rate on the F22C they needed to reduce the redline. That doesn't mean that if you up the redline to 9000 your engine will fail. It means that out of a given sample set of engine run over a certain time frame more will fail than is acceptable to Honda's business plan.
I am happy to run an F22C or stroked F20C to 9000 if it is making power at that range. But it would be a fully blueprinted engine with everything perfect and balanced to the Nth degree. And sure it could possibly fail in 50,000Km but I expect by then I will have swapped it out for someting else anyway.
All I'm saying is that once you go outside Honda's guidelines don't expect Honda reliability. Yous rolls ya dice, yous takes yous chances.
Old Mar 13, 2006 | 04:52 AM
OGPackin's Avatar
I have the setup in reverse. Ap1 block with Ap2 head w/ springs and retainers. We dropped the redline to 8800rpms.....My car loves the setup.
OG
Old Mar 13, 2006 | 07:55 AM
Wisconsin S2k's Avatar
The 11,000rpm refers to accel/deccel rates and rod angle.
As I mentioned in my initial post, Honda lowered the redline on the F22C to maintain a margin of safety. I also stated that you should only proceed if this margin of safety was not important for you. In my last paragraph, I also suggested replacing the rods for cheap insurance if you didn't want to take the risk.
They lowered the redline due to accel/deccel rates and rod angle. There has been official documentation FROM HONDA saying this exact thing, posted on these forums. they were actual scanned in pdf documents.
the rods are NOT the biggest risk.
Thus, the S2K rods are vastly superior to the rods in Honda's B20, H22 and K24 motors. So for eg., if the H22 rods can handle 9,000 rpm, the S2K rods surely can. The F22C has the same 90.7mm stroke and a more favourable rod/stroke ratio than the H22.
this logic is flawed. you're still trying to relate other cars to the S2000, and you can't. it's a completely different engine, and a completely different design.
Not really sure what your point is...specifically, to which article/posting in the oil journals do you refer?
all of it. the statement that a "real" synthetic will somehow magically protect the engine more is nothing more than marketing fluff.
All aftermarket rods come with their own rod bolts. Stock rod bolts will not work with aftermarket rods. Thus, replacing the rod bolts was implicit in my recommendation to replace the rods with aftermarket units.
That's not what you said. You implied that replacing the rods would address the issue. However, you implied that the rods were the issue, when they really aren't.
this is pretty ridiculous. I'm just repeating myself.
exactly.
Old Mar 13, 2006 | 07:57 AM
the prediction is that eventually, a failure of some kind will occur, if someone takes an F22 and ups the rev limit to 9100 and actually uses it. whether that is 10,000 miles or 40,000 miles who knows.
most who HAVE done this mod, don't even go much above 8500. so that doesn't give us very conclusive results.
Old Mar 13, 2006 | 04:52 PM
LUVNMBRS's Avatar
I disagree. If the mean piston speeds are the same, the accel/decel rates should be the same. Using the AP2 at 9000rpm and AP1 at 9718rpm as an example, although the AP2 piston/rod must travel a greater distance (90.7mm vs. 84mm) per stroke, the AP1 piston/rod must travel the shorter 84mm distance in less time cuz' it is reving faster (9718rpm vs. 9000rpm). Thus, accel/decel rates should be the same cuz' accel/decel is a function of both the distance traveled, as well as the time it takes to travel a given distance.
Where in the world did you get 11,000rpm from anyway? Did you just pull it out of a hat or something?
[QUOTE]They lowered the redline due to accel/deccel rates and rod angle.
