AP1 Misfire Once Again
Old Jan 4, 2018 | 07:08 AM
rpmgem's Avatar
Default AP1 Misfire Once Again
What’s up guys I’m having 4 codes:
61-1 Battery Voltage malfunction
P0301 cylinder 1 misfire
P0302 cylinder 2 misfire
P0304 cylinder 4 misfire
I already dealt with this issue in the past and replaced spark plugs with OEM, OEM coil packs, and eventually had my head rebuilt at Inline Pro. They rebuilt with an AP2 head/valvetrain, Inline Pro TCT, this was done at 99k. The car now has 113,800k and no CEL has came on until yesterday when the car was idling. Never mis shifted the car, oil level is always checked and to spec. First thing to start with this process all over again is a compression check I guess...
Old Jan 4, 2018 | 08:55 AM
afzan's Avatar
Based on the first code I would suspect your battery and/or alternator
Old Jan 4, 2018 | 10:47 AM
HawkeyeGeoff's Avatar
+1 not getting enough voltage to the sparkies/coils.
Old Jan 4, 2018 | 02:46 PM
rpmgem's Avatar
I'll take it to Advanced Auto to get my battery tested and see if thats it, fingers crossed
Old Jan 4, 2018 | 02:47 PM
rpmgem's Avatar
Hopefully its as easy as the battery, will get it checked tonight.
Old Jan 4, 2018 | 02:48 PM
rpmgem's Avatar
Side note that the weather in Northern Virginia currently is below 10degrees
Old Jan 5, 2018 | 08:57 AM
rpmgem's Avatar
I had my battery, alternator, and starter checked and everything came back normal. Deciding the next steps
Old Jan 5, 2018 | 09:10 AM
Slowcrash_101's Avatar
Do you have the flickering dash? If the rectifier isn't working properly the alternator can check out and still be faulty.
Old Jan 5, 2018 | 09:54 AM
rpmgem's Avatar
Nope no flickering dash, in the morning it does seem as if the car starts slowly like the battery is weak. But everything checked out
Old Jan 7, 2018 | 08:59 PM
Soviet's Avatar
I would recommend reading the Misfire thread on here. There are a whole number of things that can cause misfires and that thread goes into a good amount of detail.
I've personally seen bad coil packs and injectors so it is possible that something else may have failed. See if you can substitute parts with a local?
That voltage malfunction sure is peculiar though.
