AP1 Rough idle, Help, engine problem ! [HELP] please
Old Nov 2, 2012 | 04:17 PM
MugenJJ18's Avatar
Originally Posted by my2ks2k
i had similar issues; my car would idle just a little rough, after i drove it hard i'd get (bank 1 lean, multiple random misfires) codes.
eventually it started dying periodically when i'd come to a stop, clutch in. the revs drop usually, but now it started dying.
took it to the mechanic, he tested my fuel pump; he says it's supposed to be pushing ~50 psi, and close to 60 under WOT.
it...was dropping to around 20. i'm gonna replace it now, and see what happens.
i know you said you replaced the fuel pump; with a stock unit? was it new or used?
Thanks for the reply!
and yes i replaced it with a brand new one, you think i should check fuel pressure?, haha FYI heads up be patient if your changing the fuel pump yourself its a REALLY tight fit, as far as your question goes; i have a hint that i might? be the fuel filter, when i removed the pump i didn't see the "sock/filter" on the end of it. however this doesn't explain strong smell of gas..?
Old Nov 2, 2012 | 04:20 PM
MugenJJ18's Avatar
Originally Posted by spets
strong smell of gas makes me think you're losing ignition on a cylinder when it happens. pull out the plugs when it happens and see if you can tell which plug is wet with fuel.. if you just replaced the plugs then it could be the coil. make sure all wiring is good, and grounds are good.
Thanks for the Reply!
i was trying to do research and just found came to confused people talking about pulling the ignition coil out while engines running, some people say older cars are fine some say its not.. any insight? could i pull the coil while engines running? would it be safe for the S?
my conclusion are bad coil? i just ordered 2 to swap around, is there anyway to test injectors?
Old Nov 2, 2012 | 04:21 PM
MugenJJ18's Avatar
Originally Posted by starchland
Could it be an iacv or the likes acting up or maybe a bad injector
what would be symptoms of bad injectors, also i have cleaned and brushed the IACV still nothing -\
Old Nov 2, 2012 | 04:28 PM
MugenJJ18's Avatar
Bad Grounds do sound possiable i know there Is a grounding point right next to the ECU IE driver side, however are there any other "small" major ground locations someone can let me know to check, something might be loose.,
thanks!
Old Nov 6, 2012 | 01:01 PM
silvermonster's Avatar
any luck with your issue?
Old Nov 6, 2012 | 10:42 PM
MugenJJ18's Avatar
No luck yet... anyone have a clue or have had the same issues as me?!
Old Nov 7, 2012 | 04:03 PM
CrZy_Vick's Avatar
If its only at idle try cleaning the IAC valve; it takes 10minutes from your day. Very easy to do. after I cleaned mine I had to reset the ECU because my car would not stop idling like it had a GIANT vacuum leak. After I reseted it. It ran awesome and it never bogs at idle or low RPM no more
Old Nov 7, 2012 | 08:04 PM
MugenJJ18's Avatar
sadly is isn't just at idle, it's throughout all revs
Old Nov 7, 2012 | 09:35 PM
boyguan's Avatar
Check grounds near battery and engine ground
Could also be ecu ground
Old Nov 8, 2012 | 07:25 AM
Adionik's Avatar
Swap coils with someone. My ran like shit and sounded like a suby when the coils went out.
