AP1 vibration under acceleration
Old Jan 7, 2016 | 04:30 AM
doggz's Avatar
Default AP1 vibration under acceleration
Hi guys, I have a vibration only under hard acceleration when cornering to the right. It seems to come from the front, it disapear when off the gas or accelerating on straight line. It vibrates a bit when cornering left, but not so much, and only under acceleration.
Thanks.
Old Jan 7, 2016 | 11:46 AM
Pinky's Avatar
Inner CV Joints. Research that. Answer is to swap buckets or buy new ones. Probably best to just swap as it's free. Just be sure to re-torque the axle nuts following the instructions posted by Billman250.
Cheers.
Old Jan 7, 2016 | 08:12 PM
Soviet's Avatar
Cheers.
X2
Also driveshaft spacer may help depending on severity.
Old Jan 8, 2016 | 06:18 AM
Slowcrash_101's Avatar
May have a wasted driver's side rear diff mount too.
Old Jan 10, 2016 | 02:53 PM
Utah S2K's Avatar
What others have said.....but first check your tire pressures. Stock '01 AP1 34 psi rear and 32 Front is what I ran for years before changing to +1 17" aftermarket wheels.
Utah
Old Jan 16, 2017 | 04:45 AM
doggz's Avatar
It was the buckets, I swap them and the vibration under acceleration has gone....but quess what, now I got some vibration (depending on engine rev) on deceleration, so probably I have to buy new ones. Thanks for answers.
Old Jan 16, 2017 | 08:21 AM
Soviet's Avatar
I have had the same experience when swapping buckets on a car that had the issue really badly but it was nowhere near as severe as the acceration vibration. I remember reading that when you swap the buckets the issue is essentially reversed to deceleration. You could look into additional improvement with axle spacers or a used set of OEM axles for quite cheap or there are solid aftermarket options like Ballade.
Old Jan 23, 2017 | 02:32 PM
jyeung528's Avatar
axle spacers would be a cheaper fix.
funny that you sensed the vibration coming from the front though.
Old Jan 23, 2017 | 02:33 PM
Soviet's Avatar
I think that was someone else. I think swapping the CV cups generally works on cars that have minimal vibrations but I think my car is beyond that.
Old Jan 24, 2017 | 02:25 PM
MrFunk's Avatar
I had the same. Replaced with new and vibration gone completely. Swapping is a cheap band-aid - fix it properly.
