AP2 clutch delay slave cylinder removal
Hey guys for those of you that have done this, have you had any kind of problems with tranny, clutch, or differential? or the slave cylinder it self? i've been wanting to do this for a long time now but just scare if there are any side effects.... thanks alot for the help and input
Side effects have been more prevalent clutch slippage on cars that have probably been launched many times and otherwise drag raced. At least that's the common theory. Maybe if the car has been driven a lot of miles with it, the "damage" is already done.
I've removed it on 5 cars so far and only 1 of them is reporting minor slipping.
You can take it out and see how it feels then put it back in if you wish.
The AP2 flywheel is about 7 lbs heavier than AP1 flywheel. Remove the CDV and during hard, high-rpm shifts the clutch can sometimes engage too quickly to allow the flywheel to spin up, causing rather annoying clutch slippage.
For day-to-day driving, removing the CDV really improves the feel and response of shifts. But if you plan on driving the car hard, either leave it in or if you take it out put in at least a light flywheel and heavy duty pressure plate.
im leaning more towards not to but couple last advices could work
thanks alot again
