Ap2 diff swap in ap1
Originally Posted by darksparkz,Nov 3 2010, 02:20 PM
Do you have a list of parts needed to do the AP2 diff into an ap1 swap? I know there's generally two ways, if you swap the flange, you'll have to recalibrate something I believe. Otherwise it's more expensive to purchase the driveshaft and such, which route is the better?
Originally Posted by Disgustipated,Nov 4 2010, 02:43 PM
I need to know this as well. My friend is swapping me his AP2 diff with 4.44's for my AP1 with stock 4.1's... what do we need to swap our diffs?
You pull the ap2 flange off and replace it with aan ap1 flange and a new oil seal and nylock nut. Then you torque the nut to a few pounds under spec and keep upping the torque until it requires 12 in/lbs of turning torque to spin the flange. PuddyDad has a good thread on here that I can't seem to find right now.
Originally Posted by s2000Junky,Nov 4 2010, 08:45 PM
I re used my old nut becuase Honda didn't have one available
Originally Posted by Billman250,Nov 9 2010, 04:06 AM
If that nut is not new, or loctited, it will move. The pattern will change in the dif and you will destroy it. Seen it a few times already.
Dredging up an old post as I am going to be doing this shortly and am VERY glad that I am reading it NOW.
Summary: If putting AP2 diff in a AP1 car and don't want to install a new drive shaft you must:
* Buy 1 Oil seal PN: 91201-PCZ-003
* Buy 1 Pinion Washer for the flange PN: 90403-PCZ-003
* Buy 1 Lock Nut(blue loctite it) PN: 90201-PCZ-003
* Swap the flange on the AP2 Diff to the AP1 flange and re-use bolts and washers.
Bill when you put in my AP2 transmission you swapped the flange out so I figure that's the easiest way to go here too!
(Edited for accuracy)
