Ap2 engine into ap1 chassi
Originally Posted by M.A.R.C.,Nov 30 2006, 07:23 PM
oh really? the harnesses are the same? then why would anyone run the ap1 ecu on an ap2 motor?
the head is designed to breathe past 8000RPM and honda cut the redline due to the added crank diameter in the 2.2L version. Restoring that extra RPM gives more power as the engine still makes plenty of torque that high.
now, you do realize honda lowered the redline for a reason. the longer crank diameter and shorter rods mean additional side loading on the block as well as higher piston speeds at a given RPM due to the longer stroke.
Originally Posted by steven975,Nov 30 2006, 09:34 PM
9 grand redline!
