AP2 Retainers upgrade
HI,
I'm looking to do an upgrade on Reatiners and keepers from AP2 to my 01 AP. Are the part numbers the ones on line 7 and 8 of the link below? Also qty of 8 of each one, right?
http://www.hondaautomotiveparts.com/...E+-+ROCKER+ARM
Thanks for the input on part numbers. I obviously will get the valve cover gasket, the one for the spark plugs and some spark plugs but it still wonder me why some people are paying like $600 to get this done. I mean for this easy but very delicate job I wouldn't give my car to a newbie mechanic but there is not even $25 bucks inluding the shipping
It does take a good 3 hours to do, between removing the valve cover, the cam caps, rubber banding the rockers and lifting them out of the way, prepping the cheap tool to compress the valve springs etc etc. Maybe it's just me, I like to take my time doing engine work because mistakes can be very costly.
I posted a detailed thread with good pictures when I did the job. TAKE YOUR TIME and carefully lay out the parts as you disassemble. I spent a ton of time trying to line up the first one, but it got exponentially faster once you get the technique.
Also make sure you aren't stupid like me and leave a ratchet on the crankshaft bolt when you go to start it right after
