Apex'i V-AFCII initialization + setup
Ok...so I'm gonna go get my car tuned some time next week most likely but I want to install the V-AFCII before I get to the tuner...I'm gonna plug it in but in the manual it says that I have to do the inital setup before I start the engine....this involves the following:
Cylinder (that's obvious)
Throttle Sensor
V-Tec Type
Throttle Sensor Type
I need help inputing these numbers...as for the rest I'm gonna zero out the previous owner's numbers and go stock until the tuner gets a hold of it
btw: the previous owner had an AP1 and mine is an AP2...that's why I'm hesitant to go with the same initial setup setting as the oem parts may have changed between model years
HELPPPPPPPP
thanks in advance
Throttle Sensor
V-Tec Type
HELPPPPPPPP
thanks in advance
Originally Posted by midnightmethane,Aug 7 2008, 01:43 PM
but ap2 is different in regards to settings like vtec and throttle sensor type...somebody have a link??
You can set the VTEC engagement anywhere from 5500-6000. The throttle position sensor is the same type on both ap1 and ap2.
Most important thing is to keep the afr corrections at zero.
