ate super blue (pic)
need to change out my break fluid. so i picked up some super blue(1liter) today and i read somewhere here stating the left over can be used for clutch change also.
my question is, will it be enough for both changes?
thanks!
thanks!
Originally Posted by daktruckie99,Jun 24 2008, 04:58 PM
AFAIK it's recommended to use a regular DOT3 for the clutch. I do however have Super blue in my brake lines and I love it
can you elaborate?
Fade resistance at the Dragon was the true test. A few month old CR cooked his OEM fluid after a few runs but me and the others running Super Blue had superb stopping power even after 1hr of hard driving.
Originally Posted by ZONG9,Jun 24 2008, 05:14 PM
I use Super Blue for both brakes and clutch. I used a little more than 1 liter. I've run Sebring three times with it.
If done right, it will definitely be enough.
Brakes will use 3/4 of the bottle, there will be enough left to do the clutch res 3 times
I do notice (even though it's overkill) the ATE Super blue stays cleaner longer in the clutch res than reg brake fluid. It has proven this on many s2ks.
