Aux. outlet stopped working
Old Jan 7, 2005 | 12:32 PM
revhi's Avatar
Default Aux. outlet stopped working
I used my portable air pump the other day and had it plugged it in th outlet. Later that day I tried to charge my phone it wasnt working. I just checked the fuse and its not blown. What else could it be? Is there another fuse? The one I checked was under the dash labeled 10A I think 3 or 4 down on the left side.
Old Jan 7, 2005 | 12:36 PM
Rino's Avatar
did ya try anything else like the air pump agian??? mabey your phone part is broken
Old Jan 7, 2005 | 12:39 PM
revhi's Avatar
I tried my radar plug also, and my phone charger works on my truck.
Old Jan 7, 2005 | 12:47 PM
Rino's Avatar
is there a way for you to pull out the outlet? sometimes the male and female ends can come loose
Old Jan 7, 2005 | 12:55 PM
revhi's Avatar
I'e heard of the outlet becoming loose and rattling. I think its a common problem, but mine never got loose. Does anyone know how it comes out?
Old Jan 7, 2005 | 02:39 PM
xviper's Avatar
There is a relay for that power socket. The Helm is a bit vague about where exactly it is. It shows that it's under the dash and near the center (like near the rear of the radio?). Maybe the relay is busted. It's a 5 pin relay.
It also shows that you have to remove the whole center console to get at the power socket. However, if you have small hands, you may be able to remove the rear panel (with the hooks on it) on the passenger side and reach back there to make sure the 2 pin connector is solid.
Old Jan 7, 2005 | 08:52 PM
revhi's Avatar
Ill try that tomorrow, thanks.
Old Jan 7, 2005 | 08:58 PM
moparacker's Avatar
Accessing the back of the powerpoint only requires taking off a few pieces. Here is a thread about how to do it.
Old Jun 27, 2005 | 03:03 PM
hank322's Avatar
Same thing happened to me.. hooked up a pump to the auxillary socket and blew the fuse.. my radio and socket stopped working..
it's the 5th fuse on the left side in the interior fuse box. you may have to unplug a connector wire to get to the fuse.. it's a 10amp fuse..
That took care of my prob..
Old Jun 27, 2005 | 03:46 PM
AusS2000's Avatar
That would suggest that the aux power and radio are on the same fuse.
Does the radio work?
