backend pull under throttle
Old Apr 5, 2007 | 06:33 PM
xyster's Avatar
Default backend pull under throttle
sorry if old or stupid just got my '03 2 weeks ago I just started to notice that when I give gas and shift gears that the back end feels like it is moving to the right and pushing the front to the left and as soon as I left off the gas it goes back striaght.like torqe steer but I did not notice it before
thanks for any info
Old Apr 5, 2007 | 06:44 PM
2poor2mod's Avatar
try checking your tire pressure, may be the culprit
Old Apr 5, 2007 | 06:45 PM
antonio88x's Avatar
diff maybe?
Old Apr 5, 2007 | 06:47 PM
negcamber's Avatar
9 times out of 10 this is the problem. This car is very sensitive to tire and suspension changes.
Old Apr 5, 2007 | 06:48 PM
steve3024's Avatar
Check your rear tire pressures. Make sure it's the same on both sides.
If you have different tires on each side or if one is more worn than the other it could also cause this.
Old Apr 5, 2007 | 06:56 PM
FISH22's Avatar
tires tires tires
Old Apr 5, 2007 | 07:29 PM
brimstone's Avatar
I've noticed that especially under-inflation of the front tires causes the rear to kick out under hard acceleration/shifting... just noting that for posterity; as everyone said, check your tire pressures
Old Apr 5, 2007 | 07:32 PM
ShocK's Avatar
Mine used to do the same thing, even with the same pressures in the rear, try getting an alignment, mine went away after a 4wheel alignment.
Old Apr 5, 2007 | 07:36 PM
harrrrry's Avatar
It's an S
Old Apr 5, 2007 | 07:58 PM
ShocK's Avatar
^^ yeah mine is still slightly noticeable but I can live wit it
