Bad flywheel?
Old Sep 15, 2007 | 02:50 PM
s2guru's Avatar
Default Bad flywheel?
i was going to use this flywheel with my new engine ( for boost )... so i removed the flywheel today and this is what i found.
is the flywheel still good?
Old Sep 15, 2007 | 03:32 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Someone cut that flywheel, and in the process cut down the dowel pins.
If you want to use it, you'd have to get new dowel pins. From the hammer marks, I'd re-cut it to be sure it's true.
bottom line, I'd toss that thing in the garbage.
Old Sep 15, 2007 | 04:38 PM
s2guru's Avatar
so now the questions is? i have a big setup with a lot of boost, a light flywheel is not good for my setup. so should i buy a new stock flywheel,?
Old Sep 16, 2007 | 06:03 AM
S2KPUDDYDAD's Avatar
The Billman250 is right, what a crap job. Honda has a 2 step flywheel allot of machine shops do not know this and perform a job like this
This is what it should look like
Find your self a good used AP1 flywheel ($75.00) and start over, good luck
Old Sep 16, 2007 | 06:49 AM
TheCarGuy2021's Avatar
https://www.s2ki.com/forums/index.ph...f=107&t=522219
The Fonze
Oct 4, 2012 01:27 PM
wilch
23
Jun 19, 2007 08:16 PM
LagunaS2K
May 13, 2007 09:21 AM
