bad oil consumption
i have a ap1 y00 and it is burning alot of oil. I was wondering if anyone has come up with a solution to this issue. Im wandering if i rebuild my motor if this will even help or if im doomed...
my car now has 146.xxx miles and i know its getting close to rebuilt time..
If anyone has any tips and tricks or knows why its buring major oil please let me know.. my car doesnt smoke or smell of burning oil.. it just is getting eatin up..
well i havent replaced my pcv at all before.. i used royal purple. i check my oil lever yesterday after 2500 miles and it had less than 1/4 on the dip stick?
what will changing the valve cover do exactly?
i driver 100 miles a day around 80 mph average speed..
You mean that 2500 miles after an oil change you are only 1/5 or so up on the dipstick? The top and bottom of the measuring area on the dipstick is 1 quart, not the whole oil capacity.
That means you have burned about 4/5 of a quart in 2500 miles. That's like 1/3 of a quart every 1,000 miles.
That's pretty normal (better than normal for an AP1) and nothing to be alarmed about whatsoever!
The AP2 valve cover (04-05 model only! 06-08 won't work) has the PCV valve in a different location and has a baffle to prevent oil from being blown out during hard right turns when the crankcase has positive pressure. If your oil usage is as you state, you have no need at all.
so on the dipstick your saying that the part that has the squigidly lines is only a quart? like when i pull the dipstick out there is really no oil on the dipstick at all.. so there is still oil in the pan???
sorry, on the valvecover recommendation, the 04-05 cover allows you to use the improved pcv system of the ap2's, it has helped quite a bit on my 2002 ap1, but it depends on your driving style as well. It has helped in my situation.
Judging by the description of your oil consumption it doesn't seem anywhere near the critical level, but you better get in the habit of checking the oil level more often - once a week or every time you fill up the fuel tank, you can do some damage if you run the car with a low oil level.
If you aren't married to Royal Purple try a different brand of oil and compare the results.
Yes, the distance between H and L with the squiggly lines is 1 quart. No oil on the stick means you are over a quart low...exactly how much is unknown, but more than 1 quart.
