bad rear differential mount....
Can a bad rear differential mount cause a noise during acceleration? I brought my car into honda because of a loud squeaking/grinding/clicking noise coming from my left rear wheel... the mechanic thought the hub and bearing went bad so he replaced those parts but that didnt fix the problem. Now he's saying that he needs to replace the rear differential mount because it's leaking fluid and he thinks replacing that should fix the problem. I really don't see how a bad mount can cause all this noise... Has anybody experienced this problem before?
this is the part number # he gave me since I'll be doing the work myself.
Part number 50740-S2A-023
Part: RUBBER ASSY., L. DIFFERENTIAL MOUNTING
Guest
Posts: n/a
I need to replace one on the left. Is it as straightforward to replace as it looks? 4 bolts for the mounting bracket, and one nut in the center? Support the diff with a jack?
is it worth doing the other side at the same time?
cheers
@00derek: You either have to unbolt the diff, or drop the rear swaybar to get enough clearance of the diff studs. Other than that it's just unbolt and replace.
Didn't notice you said engine mount. We're talking about the diff mounts. Even so, I wouldn't be afraid to use it if the bolts would stay put. People run much harder compounds on aftermarket mounts.
On the diff mounts, there are two pieces of webbing that you leave in that keep everything alined. Window weld is pretty flexible. I'd say more so than innovative mounts. It's only 55a on the hardness scale. I don't notice any extra noise or harshness. It does feel more solid in the pedal though. I took a bunch of pictures for a write-up but never made it.
Guest
Posts: n/a
Originally Posted by starchland' timestamp='1323109446' post='21212264
I would do both. Using window weld or urethane wouldn't be a good idea since the motor mount is ripped, it may cause other mounts to go prematurely or cause more problems $$.it may work on a good condition mount however
Nevertheless, I don't want to start this myself if I'm not sure, so please, anybody who has done this, put my mind at rest. Can I drop the diff without disconnecting the prop?
