Ball Joints
Old Mar 12, 2007 | 06:20 AM
TrackStar's Avatar
Default Ball Joints
I was wondering if there exists an aftermarket replacement for worn out ball joints. I know in the past I was told the entire control arem or knuckle had to be replaced if a ball joint went bad. Is this still the case?
Old Mar 12, 2007 | 08:08 AM
RACER's Avatar
The lower is replaceable, the upper is replaceable through replacing the upper control arm for about $150-$160.
Old Mar 12, 2007 | 08:24 AM
TrackStar's Avatar
The ball joints themselves are replaceable, or do I need to purchase a knuckle assembly?
Old Mar 12, 2007 | 08:26 AM
RACER's Avatar
Old Mar 12, 2007 | 08:29 AM
RACER's Avatar
Which joint are you refurring to? I will assume you are refurring to the lower ball joint.
click here
Old Mar 12, 2007 | 08:54 AM
TrackStar's Avatar
Thanks man! Unfortuneately I need it for the rear knuckle I have to see if it will fit.
Old Mar 12, 2007 | 08:55 AM
RACER's Avatar
left front upper ball joint
If ya want an upper ball joint, ya have to buy the whole arm.
Old Mar 12, 2007 | 08:56 AM
RACER's Avatar
right front upper ball joint
Old Mar 12, 2007 | 09:04 AM
RACER's Avatar
[QUOTE=TrackStar,Mar 12 2007, 09:54 AM]Thanks man!
Old Mar 12, 2007 | 09:13 AM
TrackStar's Avatar
That sucks. I blew a wheel bearing and i noticed that the ball joint had a torn boot and was a little notchy like there was grit in it. I might see if I can have it cleaned, regreased, and re-booted when I take the assembly to have the bearing pressed in.
